Carb guys what fuel pump setup?
1 reading
29K views 43 replies 27 participants last post by  turbo2256
#1 ·
I am getting ready to do my carburetor fuel setup. Most guys I work with say Holley blue pump, is that right or should i look another direction i want to keep it under or around 150. I also already have a regulator from a holley blue pump kit. Also what are you using for lines? As anyone reused a EFI line for it? The carb setup is just something i want to try so i dont want to tie a couple hundred bucks into fuel lines when it might all come right off in 6 months.
I was thinking about running a Holley red pump for the motor and than another holley red pump and small fuel cell for when its on the bottle, would that be a good setup or would it be dumb to add that weight?
My setup is just windsor heads,TF1 cam, longtubes, holley 600 carb, and eddy rpm performer intake....Thanks
#5 ·
LOL yes I forgot about that! Pretty bad when you can hear the pump over the Lt's and prochamber with no mufflers.
The only issue I had with mine was the rubber line used to extend the pickup dry rotted and got a pinhole in it. I was driving home one day and went to accelerate away from a light and had no power and then it stalled. Fired right back up and drove another 1/4 mile and stalled. Then it was hard to start. Got it started and it would idle but as soon as you touched the gas it'd stall. Like sucking through a straw with a hole in it. had to dro the tank with 1/2 tank of gas in it and replace the hose. Cheap fix but a pain in the arse!
#12 ·
Ran the cheapest possible set up on my car. Its summit fuel kit comes with all lines (braided) all fittins(anodized aluminum) holley fuel pump and a chrome fuel filter as well as a fuel pressure adjuster for lik 200 bucks if i remember right supported me easily to 400hp
#30 ·
I am in the process of installing the Summit kit as well.Looks to be a really nice kit too and saved me a ton of money not having to buy things separately.
Yes you can lead a horse to water...........but you cant make him drink.(LOL)
#15 ·
Everyone i work with runs the holley pumps and the carb is a holley so i figured i will just go with it, i have read some mounting tips to help quite down the pump!
Does anyone think a one holley blue pump can handle a N/A motor with around 340 flywheel hp and a 150 to 200 shot?
If not i might do a holley red pump for now to get it going n/a than add another pump for the shot later with a little fuel cell!
#19 ·
I run the Holley blue on my setup. Very noisy but it's a race car, if it was a street car i'd go with the Mallory. I have an in tank pick up (designed for a carb) and got a 25ft roll of aluminum fuel line (need a 37 degree flare tool) from Summit and plumbed it all in. Just needed a few fittings and their fuel filter (red/chrome) and all is good, no complaints.
#21 ·
If it may only be temp, then leave the stock lines alone. How do you plan on connecting the pump to the hard lines to the regulator ?
If you're going to do it, do it right and don't do a hack job. Buy one decent pump, run braided line and be done with it.
#22 ·
If i run braided line than i will have more money in braided line than i have in any other part on the car!
My plans are to rubber hose what i have too, I will only run the fuel setup for around 6 months than if i really like it I might do braided line or some other kind of hard line
I looked up the summit kit that was spoke about in a few post above its over 300 bucks now, i still have a week or two before i need anything fuel related so i got time to figure everything out!
#28 ·
I ran a holley blue with my 302,stock lines and a 150 shot without a problem. When I stepped up to the 180 shot I ran out of fuel. I'm not sure if it was the pump or the stock fuel line being too small. Hope that helps. I'm going to run 2 holley blue's off of my sumped tank and run another bigger line to the front so I have plenty of fuel for the 347 when I eventually get to spray it.
