Hey guys, just got back from the track. first time out with new combo. when I switched from EFI to blowthru carb, I forgot to set a rev limit on my ignition box. While doing the burnout for my first pass, I over-revved the car. When I drove out of it and it hooked, the engine sounded bad (like a bad plug) the car made the pass, and felt good, but was missing. Checked all plugs, all looked good, so I went another round. the car stalled coming out of the burnout this time and while firing it, it sounded like when you crank the engine with no plugs in it. it also sounded like it was running on six or seven cyl. I ran it anyway, and it went 1.56 60ft., 6.51 eighth mile, 108 mph. It only made 15 lbs. boost, (usually 20+ lbs.) AFR read 9.9-10.4. I get home do a comp. check. 2 cyl. only had 50lbs., and one had only 20lbs. I pull the heads, and found 4 bent exhaust valves (2 per side) but strangely NONE of the pushrods were bent. now for the questions:
1) I had .100/.120 p/v clearance (w/no gasket) and run a .050" gasket. how the hell did they hit? (you can see the marks on all the pistons)
2) can simply over-revving it cause this even with alot of p/v clearance?
3) am i missing something? does anyone have any ideas?
4) how much did i leave on the table? what should it have gone with all eight?
thanks!!
thanks!!
