Camshaft for stock 302 HO with GT40P heads
4.6K views 20 replies 10 participants last post by  CDW6212R
#1 ·
Im looking to do a budget build mustang foxbody to run in a stick class in my area. It is eight-mile track and I'm looking for recommendations for camshaft kit that will give me best performance and power. 650cfm carb, Edelbrock Airgap intake Msd distributor and msd 6al ,Gt40p heads, Stock Bottom end, 5 speed trans, 4:56 gears. Any help will be very much appreciated, I was looking at kr cam kit but i seen where they weren't good for carbed engines. Im willing to do custom cam but don't know what to ask for as far as specs. Any help would be very much appreciated.
#2 ·
You will want to pretty decent amount of duration because the valves are small. Probably want a tight 108-110 LSA too. I'm not a camshaft guru but it makes sense.
#21 ·
If you fill out the custom cam order form fully and honestly, there should be no need for further information to give. Most places are helpful once there is an order, they are used to people trying to get free help without paying for anything, and then buying an OTS cam elsewhere. So find a cam designer you are comfortable with or is well recommended, and then commit to them and let them help you.
