What do you guys have the best luck with for sealing the lower ARP head bolts?? I've seen some threads with some guys liking the ARP sealer and others liking the permatex white paste w/teflon. I use that permatex on water fittings and other stuff and it has always worked great but I wasn't sure about the lower head bolts. I ask because about a year ago I called ARP and the Tech guy I talked to came across like he almost preferred the Permatex over his own sealer. He said they both torque to the same values as with Moly. What do you guys think? Any issues with the ARP sealer?? I originally planned on using the ARP moly on the longs and the ARP sealer on the shorts. What's the best? Thanks!
