I did a search and found a little information. I have a '90 model GT with a 460 and a c6 in it. it has stock 460 iron heads that have ported and polished to CJ specs but retain the small valves. it has a stock crank and rods with 60 over trw flat tops. have no clue what cam is in it but it is a small hyd. flat tappet cam. it has i belive crane roller rockers, weiand stealth dual plane intake, holley 750 dbl. pumper with mech. secondaries, 5000 stall converter, transbrake, ATI superdampr (i think thats right), and i belive 4.56 rear gears. for ignition controll it has an old mallory dist., and an msd 6al. now for my question. at idle which is around 800rpm, the timing is 36 degrees. then at full advance it is around 48 degrees. the full advance comes in pretty low. not real sure exactly what rpm. car runs great. but I just want to know if that much timing is normal? also I have a nitrous kit on it and know that the rule of thumb is 2 degrees for every 50hp. but i was told to add another degree just to be safe. and where do I need to take the timing out at? full advance? or idle?
Thanks Luke
Thanks Luke
