Are these damaged AFR heads worth it?
1.6K views 11 replies 7 participants last post by  heavyd5
#1 ·
These are are on market place about a mile from my house. They are AFR 165 #1402, sold bare. $700.00 for the pair. Ad says damaged chamber, but fixable. I contacted the seller and he said a screw fell into the chamber through the intake and caused this damage to the chamber and one valve seat.
Are they worth it? After you figure the price of a complete valve train and then the repair, plus R&R of the heads, what would be a reasonable guess in total cost? Heads are expensive and this would be for a yet another project car, that I'm working on while I wait for my other project car to get fab work completed.
#5 ·
I think it is that second chamber from the top. Not sure if he tried to clean it up, but you can see a little bit of cratering and then the shiny area on the seat. Probably not the hardest damage to fix with a little welding and a new seat, but what does that cost nowadays? All the old school machine shops that could fix this around here are gone, and if I take it to a big name shop I'm at the mercy of whatever they want to charge. On top of that, valve train components aren't cheap. He has a good complete set of 185s also, but they are $1800 and 72cc, so those won't work for me.
#8 ·
Thanks... needed the blunt response. I passed for sure, but they were so close to me, I had at least ask about them.
The price of new AFRs seem expensive, until you try to buy a cheeseburger. No such thing as a free lunch.
  • Like
Reactions: 65fasback
#9 ·
In addition to the damage repair and needing a complete valvetrain, there is also ALOT of oxidation and pitting on the surfaces. which means milling. And these are only 165's.
IDK what a set of bare new castings costs these days (how most builders / porters purchase them), but I would imagine around the asking price or slightly more than these. I would think the owner purchased a set of new bare heads and moved all of his valvetrain over. I'd pass on these.
  • Like
Reactions: Killer95Stang
#11 ·
If you can weld, and have access to a machine shop without paying labor, even then price is high, those are old castings and had about 5 revisions since. Old eye brow heads where pre 8mm stuff for sbf castings so even his valve train is useless on a new casting. See people trying to sell those as if there same as the current afr heads all time, most of the asking more then they paid for them new..
#12 ·
Bought a set of Renegade 185s with the 72cc (?) chambers for $200. I don't regret it....but I have a tig and some time. I did have to buy springs and valves though. Had they been more, I would've passed. I understand guys wanna get as much as they can for parts but used heads, even at 50% of their cost new, are going to need at least seals and I've got no idea how long those springs were on it nor the abuse they've had.
