Are the 94-95 cobra rockers actually 1.7 or 1.72 ratio?
1.8K views 8 replies 7 participants last post by  Sinful
#1 ·
I have seen some guys in their sig list 1.72 cobra rockers. Are the 93-95 OEM alum. roller rockers actually 1.7 or 1.72 ratio? The FRPP catalog says 1.7. Let me know. Thanks
#3 ·
Yea, as Anaconda stated, they are the 1.7 Crane pedestal mount rockers.
Anyone who owns a 94/95 Cobra and lists the 1.72's, or even 1.72 stud mounted rockers has aftermarket rockers installed.
Are you upgrading your rockers, or looking for replacements for a bad set?
Dang - 2200 actual miles? Do you drive it? LOL!
Oh yea, your PIH, did you just install it, or did you have to do any mods to the wiring (don't recall if I asked you before, since I have a PIH kit to install and Pro-M's website instructions are not all that clear.) PM me if you don't want to discuss in this thread.
THX. :)
#5 · (Edited)
http://www.brothersperformance.com/shop/mustang/cra4474616.html
haha it says they are 1.7 AND 1.72 ratio here...
Full roller tip and body design for reduced friction.
Direct bolt on for most stock and aftermarket cylinder heads.
Adds approx 10-15 horsepower.
May require the use of aftermarket valve covers for clearance.
Kit comes with shim kit for adjustment.
1.72 ratio.
#8 ·
AJ, what is a eagle/srp/306? What components are in that. I am getting parts together for a 306 and I got a new FRPP stock replacement 5.0 nodular crank, .030" over SRP flat-tops, and crower 4340 sportsman stock length 5.09 rods. Is this similar to your combo? Do you happen to know how much skirt clearance you run with your SRP's? Thanks
