are flowmasters
424 views 7 replies 4 participants last post by  ninetyninegeetee
#1 ·
that are welded on are they 2.25" or 2.5"..the previous owner of my car had them put on...and he told me the exhaust is 2.25 but im sure its 2.5"..anyone?...
#6 · (Edited)
I haven't measured them but I had the Magnapacks installed with the stock H-pipe so from that I conclude the stock H-pipe is 2.5" 'cause they welded it directly to the Magnapacks and everything fit perfect. I did measure the tips and they are 3" like mustangdreamer said. I can send you a pic if you want. Just gimme your e-mail addy.
#7 ·
ninetyninegeetee said:
planning on getting the catback...i was told that the mufflers will probably need to be spot welded on?....
I don't think the muffler has to be spot welded on...I have the magnaflows catback and there are stainless steal clamps that connect the muffler (in your case glasspack) to the tailpipe and another clamp to a small section of pipe before the midpipe. If you do spot weld them that would be better in the long run I guess.
