im thinking of getting rid of my X cam and going with an anderson N-41 just wondering if others have used this cam and what they think of it
Thanks Keith
Thanks Keith
well in that case, i will throw an 1.503 inch lift cam in the car! LOL....it will have the same result as the stock cam.........the valves will open.Isnt that what I said?
If you are talking about ramp rates, save your breathe! I know what lobe seperation is! I understand what duration is!Lift isnt even half of the equation!
You have alot to learn..
Duration throughout the the profile have far more overall effect .
Then there is lobe seperation and timing events also.Lift falls at the bottom.
Then how can you call the X cam bigger cam? Unless you are purely talking lift.If you are talking about ramp rates, save your breathe! I know what lobe seperation is! I understand what duration is!
because it is bigger in that aspect!Then how can you call the X cam bigger cam? Unless you are purely talking lift.
The N-41 is alil smaller then the N-51hr the specs for the N-41 are 222/232 duration and .512/.512 lift w/ 110 lsI'm running the Anderson N51hr and personally I love it. It's a bit ignorant below 2000rpm but pulls hard up to my 6300rpm shift point. I don't know the specs of the n41 but the n51hr is 226/234 duration .520/.528 lift, and a 110 ls.
You really need to learn how to read!hey Blackout explain how the x cam is more efficient than the N41, when it has more duration, more lift and a lobe seperation of 107 in a stock headed 302 and the guy wants to spray a 200 shot![]()
even if he changes heads, the lobe sep. is wrong for nitrous
explain to me how the x cam will be more efficient with the 107 lobe seperation spraying nitrous cause i'll have to call all the cam companies to tell them change all their grinds because their wrong using 112 and 114 lobe separation on nitrous hydro rollers
small head + X cam + nitrous = efficiency:rofl:
More like you didnt understand what you were reading!never had a alphabet cam and never will, the only specs i could find were duration , lift and 107 lobe seperation, guess catalog had it listed wrong! Guess i won't have to call the cam companies.
I was thinking lack of IQ but if thats what you think run with it..Must be the clean air and water to your North that must be making me not comprehend what i read!
Apart right now but Im sure its seen more passes than any heap you have owned.You run that coupe or are you a bench racer?
