Thanks for your post...but the reason that I do not want an aluminum flywheel is that I DO want to shock the tires on a launch, I want that brute force feel when I dump the clutch. These cars are weak on torque to begin with and I do not forsee a power adder in my future in the next year or two at least. I am aware that an aluminum FW will rev quicker and easier due to the lighter weight and less inertia, but out of the hole on a hard launch, given the lack of torque, I would tend to believe that the harder the hit on the tires, the less likely you are going to bog the motor since the inertia keeps the flywheel going on a 4k launch. In this same situation an AL FW might lose rpm easier because of the lack of inertia. Now on a high horsepower/torque motor, this would not be an issue, but on an otherwise stock mustang I would think that I may have this problem. I am by no means knowledgeable on this, but I'm just going with what I see as common sense. Am I right? Any thoughts?
So back to the original question...is the billet steel flywheel worth the extra money over the stock flywheel??? And again, what about chatter?
Thanks for the help!
Mike
