Accufab 90mm TB spacer and EGR
1.3K views 8 replies 3 participants last post by  Mustanglimey
#1 ·
Been out the game for a while so need some refreshing:idunno:
About to order a Accufab 90mm EGR spacer to use my existing throttle setup from my old engine.
Do I need to run the EGR or can I get a delete plate?
My old setup used it, or at least it was on the TB....will check.
I run the factory ecu with a PMS IV.
#2 ·
It's a waste to buy a plate, just get the TB unless you absolutely cannot move around your intake oipe..
#3 ·
Not quite following, been 3 years since I pulled the old motor...
My old engine had a 75mm tb with the plate to connect my throttle cable... I was gonna buy the 90mm version.
Was wondering if I can dump the EGR on the bottom of the TB and put a delete plate on there. That's the main issue.
#4 ·
EGR in the upper photo?
#6 ·
That's your IAC on the bottom towards the V/C unless I'm missing it and having a senior moment. I had mine turned 90* more counter clockwise than you do, with it to the front pointing vertically. You could just keep your 75mm plate and opening it up to 90mm, or buy a 90mm like you said. I'd be interested in buying your 75mm, it's it's the last pc of the puzzle I need...PM me if your interested..
#8 ·
Doh...no I'm having a brain fail...your right :eek:
Thank you ;)
I'm in the UK but I'm sure I could ship it to you cheap....I sent my Anderson PMS back, the postage quotes from dealers are a rip off!
I'll pm you now.
