95 master cylinder and booster install
1 reading
352 views 2 replies 3 participants last post by  Adam Dugger
#1 ·
I just finished installing the 95 booster and MC on my 92 LX. Thanks to Dugger Racings site it was a lot easier. His photos of the installaton was a big help.
The only problem was indenting the strut tower sheet metal for booster clearance. I wound up with a nice looking cresent shaped smooth scallop in the tower. A ball peen hammer seemed to smoothed it, after using a brass hammer. It took me 2 days and 3 types of hammers and some skin. The problem is that there is no room to swing a hammer. I then repainted the bare metal with a spray can.
I previously installed a M-2300C rear disc kit that came from Racer Walsh. I also installed Lincoln front calipers and adjustable prop valve. The kt came with a huge all aluminum, 86 style MC. It had a piston diameter of 1.00 inches. The 95 MC had a 1-1/16 in. piston and is alot smaller.
I couldn't hope for better brakes than I have now. They will lock up easily. So it would be nice to have a antilock system. Has anyone done this on a Fox body. Is it expensive.
#2 ·
Look at the tech article in the corral tech article section. Then do a search for ABS in ONLY the "General Mustang Tech" section.
#3 ·
Glad to see the article helped you. Its not an easy job, but its worth it.
Check stangplus2birds own site as well for the ABS info.
I've never even considered doing the swap.. no doubt its a TON of research
