90 Supercharged Coupe in Ga F/S or F/T for a 93 Teal Cobra
1.9K views 23 replies 5 participants last post by  so_r_crazy
#1 · (Edited)
90 Supercharged Coupe in Ga F/S or F/T for a 93 Cobra
1. 302 built motor with forged speed pro pistons, Scatt crank, custom grind cam, Gt 40 p heads with manley valves, 1.7 rr, 42 lb inj, cobra intake, 65mm tb, 80mm mass air, underdrive pulleys, Vortech S Trim with Anderson powerpipe. About 3000 miles on motor.
2. Coilovers in front with lakewood 90/10's with QA1 175lbs springs, Steeda caster camber, and sub frames
3. 5 lug conversion with FR500 wheels 17.9 in front and 17.10.5 in back with 275 40 M/T drag radials.
4. Lentech auto with fully manual valve body with push button overdrive with trans brake and 9.5 converter 3200 stall, holds up to 1,100 hp.
5. Rear consist of 373 gear, detroit c locker, 31 spline moser axles, and a trick frow differential cover.
6. Eibach drag launch kit on rear with Mega bite jr's lowers and ground pounder uppers.
7. Bassini exaust with 2.5 tail pipes, Mac shorty headers and Mac H-pipe.
8. 255 in tank fuel pump with t rex inline.
9. 93 Cobra Tail Lights
10. Cobra Grill Insert
Very nice street/strip car. $15,500, or consider trades for a 93 cobra. Will email pics if interested. Its is a very clean car.
#15 ·
Is this an original 5.0 car or a 2.3? Has front bumber cover been replaced because it looks like the rivets that hold the headlight panel to the bumper cover are missing? Ever been wrecked? Thanks
Save
#16 ·
Yes its a original 5.0 car I had the bumper put on when I bought the car about 10 years ago cause it had some kind of boss ground effects on it. As far as beiing wrecked I have never wrecked it since ive owned it. I just had it painted about a year ago and had a cobra grill insert put in it.
#17 ·
I have not seen a a 5.0 without a leather wrap steering wheel. In the picture it looks like it doesn't have a leather wheel. Do you think the wheel was replaced for some reason? I guess someone could remove the leather, but I'm not sure what the wheel would look like underneath. Also what was the original color of the car? Thanks
Save
