8.8 Pinion solid sleeve vs crush sleeve.
1 reading
6.6K views 8 replies 8 participants last post by  my8950
#1 ·
Rebuilding my 8.8 and a friend told me about using a solid pinion spacer instead of the crush sleeve. Makes it easier to set up?
Anyone else using one?
#6 ·
As did I.... http://forums.corral.net/forums/showthread.php?t=1225018
I'm going to try a standard crush sleeve because I've already got one that came in my bearing kit, I'll see how it works out in a day or two. If it turns out to be too much of a PITA I'll order up a solid spacer.
Ratech also makes a special crush sleeve that is supposed to be easier to compress, haven't seen anyone actually running one though.
#8 ·
I am going to get the solid sleeve and shims. Need more shims to be able to set this rear end up correctly I think. NONE of the parts going together have ever been mated with any thing in this combo. Mustang housing, Truck carrier, Strange axles, new gear...
