What are the advantages/disadvantages of the two balances? Is is only the damper and flywheel/flexplate that determine balance or is is 'built into' the crankshaft? Can any explain it all?
T
T
Good one Kuntothis is overall the best when there is a heavy acessory load such as a ... turbo
great, three people are now waiting for explainiation of your belt driven exhaust driven supercharging device you mentioned - but instead of answreing that you simply reiterated something someone else already said without adding anything to it; using that as a vehicle to yet again mock my name. Your decision to mock my name instead of clearing up your statements is interesting insight into your decision making process.hamit off,
why buy a cast stroker crank...???
cost...
Cool thread is cool
So, balancing is more critical for rpms and not horsepower then? I'm trying to budget my new motor. If I can save $500 bux and use my stock damper and flywheel for a motor on the stock 6250 rev limit, then that would work for me.
What do you think?
