5.4L Navigator Question
1 reading
19K views 18 replies 7 participants last post by  ATOMonkey
#1 · (Edited)
If Al aka BOSS 330 reads this please help. I have a 2002 Mustang with a 5.4L Navigator crate motor I got from Ford. It has the forged crank and the stock 9.50:1 compression ratio pistons and rods. I am wondering what kind of horsepower numbers the bottom end can handle? Also how many PSI can it withstand? I am planning on running about 14-16 PSI from a 03 Cobra eaton superchager system that has been modified to fit the 5.4L. The engine has ported and polished Navi heads with stage 2 Cobra cams and ARP head studs. Am I safe to run this setup or should I lower the PSI from the supercharger untill I build the bottom end up with forged rods and pistons? I know when I decide to upgrade to the 3.4L Whipple the bottom end must be built to withstand the 25-30 PSI I will throw at it.
#4 · (Edited)
The rods are the weak link in the Navi engine, they will take roughly 400 RWHP. For the boost and RPM that this motor will turn in a mustang (the rev limit in the navigator is set @ 5500) you will not make it past 400 HP for long.
We suggest a set of Manley H beam rods and pistons to reach you PSI/HP goal otherwise dont waste your time installing it.
Let us know how we can help.
MMR
1-877-MOD-POWR
