408w or 427w
666 views 5 replies 4 participants last post by  wldtang
#1 ·
Trying to decide which to build. This will be in my 94 cobra and will be a street car. Might see the tracks a few times but rarely.
Parts to go on will be vic jr heads, vic efi intake, custom cam.
Any pros or cons of either the 408 or 427?
#2 ·
408 personally, you also must also be careful when using a crank larger than 4.00 inch in a windsor block, it obviously can be done though. I had a guy put one together, didnt check rod clearance in the cam tunnel, well you know what happened when he started it :)
#3 ·
I have a 408, but I would go with a 427 if I had to do it again. But a 427 is going to need some serious breathing room, a 408 may suit your heads better.
