My engine is needing a rebuild.. 140K and oil leaks all over the place.. I think I might as well build it a little. But on a limited budget. Just looking through the forums and reading some mags I'm thnking a good plan would be a 347 Stroker Kit and a pair of AFR 165's. Aside from prepping the block when disassembled would I need many other parts to complete this? Bigger injectors, fuel pump, MAF? Might do a cam at the same time but not sure which one would match up well with those other pieces...
Thoughts?
Thoughts?
