302, 331, 347, 363, 393, 408, 427 which one and WHY?
22K views 64 replies 27 participants last post by  biggjupiter
#1 ·
Started off small, just adding a good top end to my stock block 91 5.0 stang. Just breathing better Really woke the car up well. Well enough that I want more. For a while I was thinking 331/347, then 363, now 408, and since I was once considering a dart block in the 363, why the hell not a 427 or very big inch dart build. But then you see videos on you-tube or the like showing 306's and 331's just plain kicking butt on, and off the track, for what should cost tons less than a dart, and a dart/9.5 build.
The grass is always greener it seems, but for people that have owned or experienced a few different Windsor builds, why did you go the route you chose, or would you do it differently if you didn't already have what you have?
I think a 408 is a good mix between budget and power with the displacement, but I'm sure there's a little 306 that would love to show me how wrong I was after building or having one built, hahaha.
In the end, I think 500-550rwhp, and an od/auto trans in a car with a good working suspension would make me smile, but maybe a lighter 347 with a little less power with a c4 might be quicker???????
#2 ·
How fast do you want to go? How much noise do you want to make? Street car? Want to use a factory hood?
There is never a replacement for displacement, but it all depends on how you plan on using it.
I had to start from scratch, so I built an NA Dart SHP 427w. Turns out I wanted a sleeper (something quiet) and I probably should have opted for a Turbo 351w...something without a big lopey cam and the rumble of large displacement.
Reliable 500 to the wheels is outside the realm of a production 302 block. My honest opinion...if you have the extra cash, start with a partial 4 main block like the SHP. Build it on the side, then do a swap.
Don't forget to take supporting mods into consideration...a $10k motor may cost you an additional $10k in supporting mods if you want 500hp. All the little things add up.
#5 ·
Someone will always build something better, especially if your working with a budget. Put enough turbo, blower, and or N20 to a package and you can have a 4 cylinder embarrass the badest of the bad. What do you want? Street performance? Drag race success? dyno numbers for parking lot bragging??? What will make you happy?
#6 ·
I chose a 363 since it would look like a 302, be lighter weight than a taller block with the same parts, and fit like a 302. My primary goal was to have it look and fit like a small engine.
#8 ·
More cubes give you big torque and power at a lower RPM than a smaller sized engine...perfect for street use. This is NA applications of course.
Do you want 500 HP at 5500 or 500 HP at 6500 RPM?
#11 ·
Do the cubes unless you have a class rule to deal with.
I have a nasty 363, but I wish it was a 438.....
#18 ·
450"-460" in a RDI/fontana/shelby block is the way id go
4.125 or 4.250 stroke with a 4.155 bore
will be an absolute torque monster down low. and with the right parts you can spin them to the moon
#29 ·
^^^ truth...but this will NOT be a cheap date ;). Engine builder has one in a sleeper/grudge car w/Victor heads & Progressive fogger...runs high 5's on motor( E85 street car)...and just a lil faster on the fogger:). Block alone was $4,500+..not including machining. Another friend is doing a 461..same block,but using CFE heads/sheet metal intake..probably going to be a $20k + motor when done. Small blocks can get Rediculously expensive...but it is great to lift the hood after outrunning & taking $$$$ from a 632(or bigger)BBC car with 2 systems on it..with a grungy/greasy, flat black "351":evil: :leghump: I say a 408 in an early block if on a tight budget...or a 427-454 if you can afford an aftermarket block. If u NEVER plan on going over say~650rwhp or 7,000rpm on a regular basis..408 in stock block is the answer.
#19 ·
At that point, why keep playing with the little toys, same cost for everything, except maybe heads depending on ultimate goal. Go big block... RDI, 4.650 bore 4.75 stroke, 6.7 oliver rods. 645 cu in of fun.
#21 ·
i do know of a killer blue thunder headed BBF for sale right now... makes about 1300NA
#23 ·
Thor gen 2 with a C&C 10.3 block
#26 ·
Yes, Ive got the A460 block, and its a monster compared to a stock block. I pick up E7 460 block, move it around no problem. The A460, not going to bear hug it and move it. Walk that one across the floor or use hoist...
#32 ·
302 + aftermarket block+ forced air = 600rwhp.
Or...
418+ stock block + right combination of parts = 600 rwhp.
It's all bout how much you wanna spend and what your goal is.
#33 ·
Or...
With all due respect, that's a bit optimistic....if you're speaking about an NA engine making 600 to the tire, with a stock block.
Not saying it can't be done, but that will NOT be a budget build.
#35 ·
I'm betting there are a fair amount of boosted 408's not making 600 to the tires. To me making numbers happen on a dyno is a lot harder than saying them on the internet. I've been to a few dyno days, and usually when someone makes over 500, people take notice, and the highest I've seen in person, "not you-tube" are 67xrwhp, and it was well over 100more horses between it and the next highest car out of at least two dozen pretty nice street cars that was at the last one I seen.
#37 ·
But its you 10,000 sheep, and god.......
A 408 and decent heads, a little compression, not that hard to do 600hp with a good head. Hell, back in the stone age I got it out of what is basically a K302 head, 3/4" headers, a 14-1 306 with a holley HP950.......
#42 ·
im thinking the 408 im building will get close to 600 at the tire with a set of SVA heads on it.
