So I have a 4 cylinder 1993 notch back that I will be swapping a 5.0 into. I have a decent amount for a budget, but I'm looking on what things to do for my engine set up. I'm buying a donor car, it's an 88 ssp that was wrecked, and basically swapping everything over. As far as bottom end, I'm keeping it stock because if I'm not mistaken, that year had forged pistons. As far as heads I've heard AFR 165s are the best way to go with heads, which is probably what I'll use. I have a gt40 cobra upper and lower intake, which I'm gunna have tmoss port the lower. As far as cam, roller rockers, timing, and tuning what are your guys suggestions. I've read that a lot of people keep stock cams, is there a specific cam that others have experienced power increases with? Should I use a double roller timing chain? As far as tuning, I know there is quarter horse and other chips, but I've also heard of people just using fuel regulators on stock tune. What do you guys recommend for tuning for my purposes? Based on what I have listed, what do you guys who have had a similar build estimate for hp and tquality numbers? Thanks in advance for help!
