As a little background this was a 28k mile motor and trans with about 15k on the blower and was running when removed.
I was going to start putting this into a fox and primarily for financial reason's decided to put this into my SN95 instead.
I will update this as we go along but, listed below is everything that came with my conversion.
What I am curious about is hidden items and cost's that I have not already figured.
I have a budget of about $3,800 to finish the car and get it running. For now I am looking to get everything working flawlessly and worry about things like e85 later.
Here is what I need and plan to purchase
Clutch - Mcleod RXT - $800
Exhaust - Undetermined - 1k
Hood - Told it wont fit under stock - Cobra R $600
31 spline axles - $250
3.55 gears - $150-200 (already has 3.73 but, that will be to tall I think)
Subframes - Kenny Brown - $350ish
Upper and lower torque box reinforcement. - $80-100
Better boost guage - $100 (will be running 17+)
Xmember for t56?
I've done some reading but, not sure what modifications will be needed to make this work. Any help is appreciated and what good is a thread without some pics
https://www.youtube.com/watch?v=ZXEAt-1oiBs
List of Items
Whipple 2.3 supercharged 4.6L dohc Cobra engine with all front accessories and stock K member. With aftermarket metco lower adjustable and upper.
T-56 26 spline Tremec 6 speed transmission
Cobra specific aluminum driveshaft
Engine computer,
Engine harness
Computer harness
Headlight wiring harness w/ underhood fuse box
Dash harness
Body wiring harnesses
Speedometer cluster
Steering column with key and cobra airbag
Cobra specific manual clutch & brake pedal assembly
Fuel lines
Cobra specific Fuel tank with dual pumps and evap lines
ABS pump and lines
Hydroboost system and master cylinder
Cobra radiator and condenser
Cooling fan assy.
Cooling resevoir
Heat exchanger and innercooler pump
All front engine accessories in working condition!
cruise control servo and cable
CCRM
Fuel pump driver module
fuel filler neck
Powersteering pump cooler
intake hose, mass air meter and airbox
03 Cobra dashboard intact.
All wiring is from a COUPE Cobra unless noted above
Xmember for t56?
List of Items
Engine computer,
Engine harness
Computer harness
Dash harness
Speedometer cluster
Fuel lines
ABS pump and lines
Cooling fan assy.
Cooling resevoir
CCRM
fuel filler neck
