1994 / 1995 Door Panels
1 reading
4.6K views 6 replies 3 participants last post by  90lxwhite
#1 ·
I need to have one of my door panels recovered but I guess I will do both. The issue is that my oem panel was wrapped in two sections and the covers that I’ve seen are just one piece.
On mine the middle oval “arm rest” portion was a piece of molded cardboard that was wrapped in perforated vinyl. The molded piece had tabs that fit into slots in the door panel. The problem I’m facing is that the molded piece has been destroyed, so what do I do about the holes in the door panel where the old center section stuck into? If I use the one piece pre-made covers, or have a shop cover them, the material would just lay over the holes and you’d be able to poke through. The door panel clovers on the sn95’s after ‘95 were a one piece so they wouldn’t have any holes in their panels.
Does anyone have any experience with Redlinegoods panel covers? The one review I saw said that they were so so. I wonder if they’re just a thin piece of leather or if they have any amount of padding to them? One would hope so because the door panels are pretty hard and “plasticky” when they’re bare. Maybe just maybe the material that one would use, either a shop or Redline’s, would be thick enough to where one wouldn’t notice the holes underneath, but I doubt it. Any ideas?
This is the bare drivers side panel with the holes where the molded perforated center section was. The other pic is the still good passenger door.
#3 ·
Here’s a guy who used them.
I emailed redline asking if their covers had any sort of padding in them and they said that they’re just “skins.” I think it might just bet better to have a shop see what they can come up with.
#4 ·
V6 cars with manual windows/locks use that same panel. Have you tried a bone yard?
Are you sure that the 96/98 did not have the same perforated panel?
#5 ·
I don’t know if all 96/98 don’t have the perforated panel, but I know that some don’t. Awhile back my dog chewed up my drivers side door so I replaced it with one from a wrecking yard for “time being” it kind of matches the oem and passenger door, but the center piece isn’t perforated and the material covering the door is one solid piece instead of two pieces like my original. I still have the original door in the garage and it’s in better shape than the non matching used one that I’ve been using, it just needs to be recovered. I’m pretty sure any panel from ‘94-‘04 will fit, I just haven’t found any nice enough. I had an upholsterer tell me they’d do both doors for $300 but I’m not sure if if he looked at it close enough to notice the holes and if that $300 included any sort of padding in the material or not. The door panels that don’t have perforated arm rest section have a little pad that is built into the fabric in that location.
#6 ·
Have complete door assemblies from a 96 Cobra on my GTS. Wanted power windows and came across suitable doors. The perforated panels are identical as my original non powered doors. But because the donor car was a salvaged title and crossed many hands, who knows what the door panels were from originally.
Wouldn't those 3 lower slots be covered by whatever you chose for panels?
#7 · (Edited)
If I found a whole new door panel those holes would be non existent or the tabs on the arm rest portion would be sticking in them, depending on which style of panel I found.
If I had mine recovered they’d have to fill the holes or make a separate molded piece to cover and stick in the “arm rest” portion of the door and glue it down. As well as have the top portion of the door covered. The pre-made skins that I found cover the entire top section of the door (black part I circled in pic). If I went that route I’d just have fabric laying over the top of the holes. When they cover the doors the bottom section of the panel is separated from the top piece. So in my case the gray piece would be taken off and the black would be wrapped and then the gray reattached.
