1991 Mustang Coupe Street/Strip Low 10's
11K views 26 replies 9 participants last post by  slojunk91
#1 ·
1991 Mustang Coupe 48k Red/Gray int. Super Clean 10.30 @ 132 with NX single nozzle 100 shot, 11.29 @ 119 on motor. Now has NX Gemini Plate kit never used.
Engine:
DSS ProBullet Long rod,AFR 185 w/hi-rev spring,Lunati #51018 Nitrous Cam,Holley Systemax Intake,42#inj,MSD Billet Dis,Accufab 75mm TB w/90mm inlet,Anderson 4"Power Pipe,Bassani 1 5/8-13/4 ceramic headers,3" Bassani X Pipe,Flowmaster Super 40w/dumps,Pro M 80mm Race meter,Ford MS 1.6 RR,Moter is all ARP studded w/DSS main Girdle inside Canton pan.Moroso Super 40 wires. Afco 2 Row aluminum rad.Plus a bunch more i cant think of etc.
Trans:
C4 reverse manual body fresh,locally built(no trans brake).8" Dynamic TCT 4800Stall Converter, PA SFI Bellhousing, TCI 157T SFI Flexplate,Hurst QS Pistol Grip Shifter, FMS Aluminum DS.etc.
Chassis:
15x10 Weld Alumistar,15x3.5 Fronts,MT ET Street 27x10.5-15,Moroso DS-2 26x4.5-15,QA1 K-Member,Strange Struts&Shocksw/UPR Coilover Kit,QA1 130#Springs,UPR Bump Steer Kit, UPR Anti Roll Bar,UPR adj. lower arms, TRZ adj uppers,Wild Rides 8-pt cage welded to re-enforced torque boxes & Subframe conn.Flaming River ManualRack w/steering shaft. D&D Caster/Camber Plates.etc.
Rear:
8.8 with 4.30FMS gear,Moser 33 Spline spool,Moser Axles w/ C-Clip Elim.Aluminum Cover with support.etc.
Interior:
Kirkey Race Seats,Simpson 5-Way(new),Auto Meter Monster Tach,Wideband,Oil press,Fuel press.MSD Digital 6& HVC coil mounted inside.etc.
Body:
HO Fibertrends 4" Bolt on Cowl Hood. SOS Aluminum Wing(strutless)etc.
Also:
Optima lightweight yellow top battery, Flaming River Push Pull switch,Aeromotive 340 LPH in tank pump.UPR fuel rails,Adj Regulator(stock fuel lines)Moates Quarterhorse Tuning,New UPR Diamond 6 piece headlight set,Proform Electric WP inc.etc
This is one of the striaghtest cleanest coupes out there. A real 5.0 LX not a 4 cyl.P/W,P/L,P/M,Power Trunk Release all Work.
Asking $11,000
Contact me @ slojunk91@yahoo.com or PM.Thanks.
album:
1991 Mustang Coupe Street/Strip Low 10's - Imgur
Save
#9 ·
Damn, to bad I didnt see this car a month ago...GLWS!
Save
#11 ·
Thanks. Try to duplicate this car for twice whatim asking. Ive done 80% of the work on this car myself. Ive owned it since '02. All it needs is some fine tuning &a real fuel system to be high 9 sec 135 capable. This a steal. pics dont do much justice this caris super clean& straight with less than 50k originally from MS.
Save
#14 ·
Nice looking car for sure, tons of track goodies. How's it handle cruising the streets? Seems like the 4800 stall and spooled rearend would make it more of a track car.
Save
#15 ·
Depends on preference really. Everyones opinion is different on whats streetable and what isnt. I wouldnt consider it a dd but some minor changes could make it street/strip rather than strip only.
Save
