1991 mustang clockspring
10K views 17 replies 6 participants last post by  87GT Drop Top
#1 ·
does anyone know where i can get one. can't pass my vehicle inspection because i have a airbag code 6. any suggestions.
#7 ·
You have to pull the steering wheel to install a new clockspring. Remove airbag (disconnect battery first!), remove steering wheel nut, use steering wheel puller to remove steering wheel (tapered press fit, sometimes they pop right off, most times not), disconnect and remove old clockspring.
#9 ·
From '92 Service Manual... Order modified to be in correct sequence for clock spring R&R
Steering Wheel
Removal
1. Disconnect battery ground cable and air bag backup power supply.
WARNING:
THE BACKUP POWER SUPPLY MUST BE DISCONNECTED BEFORE ANY AIR BAG COMPONENT IS SERVICED.
2. Remove four air bag module retaining nuts.
3. Remove air bag module from steering wheel and disconnect electrical connector.
4. Remove and discard steering wheel retaining bolt.
5. Remove steering wheel from column using Steering Wheel Remover T67L-3600-A or equivalent.
Contact Assembly [clock spring]
Removal
1. Make sure vehicle front wheels are in the straight ahead position and steering column shaft alignment mark is at the 12 o'clock position.
2. Disconnect battery ground cable and air bag backup power supply.
3. Remove steering wheel as outlined.
4. Remove instrument panel lower trim panel and column shrouds.
5. Disconnect contact assembly harness connector.
6. Apply two strips of tape across contact assembly stator and rotor to prevent rotation.
7. Remove contact ring retaining screws and contact ring assembly.
Installation [clock spring]
2. Align contact assembly to column shaft and install.
3. Install three retaining screws and tighten to 2-3N-m (18-26 lb-in).
4. Route contact assembly wiring down column assembly and connect harness connector. Remove tape strips.
5. If installing a new contact assembly, remove locking mechanism.
6. Install column shrouds and lower instrument panel trim panel.
7. Install steering wheel as outlined.
8. Connect air bag backup power supply and battery ground cable.
Installation (Steering wheel and Air Bag)
1. Position steering wheel on column shaft, by aligning steering wheel index mark with shaft index mark.
2. Install a new steering wheel bolt. Tighten to 31-44N-m (23-33 lb-ft).
3. Connect air bag module electrical connector.
4. Position module to wheel. Install four retaining nuts and tighten to 4-6 N-m (3-4 lb-ft).
5. Connect air bag backup power supply and battery ground cable. Verify air bag warning indicator.
#11 ·
thanks. i ended up buying a 88 tilt steering column with no airbag wheel. i'm gonna try and install this. inspection station said once steering wheel with airbag is gone and light removed i'll be good.
#14 ·
how are you going to clear the airbag code once you install the 88 column?
#16 · (Edited)
OK, for the record what you're doing may be against Federal Law but it's your choice.
You need to disconnect the air bag diagnostic moninitor and the bulb. Otherwise the diagnostic monitor will beep.
On a '92 you can disconnect the diagnostic monitor and remove the shorting bar between pins 4 & 5 on the gray connector and you're done.
I do not have '91 schenematics but is should be similar. But from http://www.veryuseful.com/mustang/tech/airBag/images/airBagSchem1990.jpg
It looks the same in that reguard.
#17 ·
yea i took out all the airbag stuff. once i put the tilt column in it will be like the car never had a airbag. tired of all this inspection stuff. i just want to drive my vehicle.
