1989 Lincoln Mark VII
965 views 3 replies 1 participant last post by  re-Markable LSC
#1 ·
CHP 347 shortblock (all forged internals and H-beam rods)
Trickflow ported Twisted Wedge heads with Comp Magnum roller rockers
Comp Cams XE 284 cam shaft
Holley Systemax intake (worked upper and lower with an oil splash guard on the lower)
Anderson Powerpipe
Canton 7qt. oil pan
TwEECer tuner
Full stainless exhaust: FRPP ceramic coated headers, Basani X-pipe, Magnaflow mufflers, custom tails
Aluminum radiator with electric fan
Optima battery in trunk with billet aluminum mounting plate
March pulleys and alternator bracket
Corbeau Legacy Leather buckets on manual sliders
Corbeau 5 point harnesses
Custom matching rear leather seat
(Interior treatment is now woodgrain. The carbon fiber pictured will come with the car)
Maximum Motorsports tubular A-arms and SN95 spindles
Maximum Motorsports front coil over kit with caster/camber plates
Maximum Motorsports bump steer kit
Maximum Motorsports steering shaft
Maximum Motorsports strut tower brace
Carriage House Engineering adjustable rear upper and tubular lower control arms (adjustable spring perches) with Roush springs
Turbo coupe front swaybar upgrade, Addco rear swaybar
Welded sub-frame connectors
Tokico front struts
Koni rear shocks
Cobra front and rear brakes
Agent47 brake cooling ducts are ported through the custom fiberglass bumper and blow directly onto the front rotors
FR500 replica wheels (18x9 and 18x10) with new Nitto tires
Handling on this car is UNBELIEVABLE!
Astro A5 transmission
Stifflers cross member and driveshaft loop
Carbon Fiber driveshaft from DSS in Florida
Hurst pistol grip shifter (Mopar style)
McLeod steel bell housing
McLeod clutch
McLeod hydraulic clutch conversion with internal hydraulic bearing
Custom dash with Auto Meter GS gauges: GPS driven speedo, Tach, fuel level, water temp, oil pressure, voltage, clock .
JVC head unit with Bluetooth
PPI amps
Polk Door speakers
2-12" MTX subs in custom box
$10,000
