**SOLD** 1988 Notch for sale
3.7K views 25 replies 10 participants last post by  q6543
#1 · (Edited)
$13,000.00
Check price
Hartwell, Georgia
Year:1988
Make:Ford
Model:Mustang
Mileage:N/A
Transmission:Manual
Engine:5.0
Trim:LX
No Trades I've owned for 11 years. Bought as a roller and put a stock drivetrain in it from a 1990 hatch donor car. 5 lug conversion, rear disc conversion, welded subframe connectors. SVE coilover suspension all around. Clean car and clean title. I can provide additional photos upon request and I have a lift in my shop so underbody pics are not a problem either.
owns 1988 Ford Mustang LX
  • Like
Reactions: Deck6649
Save
#6 ·
I thought I had lost this list but found it today. Below is a list of parts I bought and installed since I bought the car. None have more than 1000 miles on them since I don't think I've driven the car more than 1000 miles in the past 10 years. I also wanted to mention the torque boxes are solid and the trans and rear end are fresh and they were done right.
Fuel Tank
Ignition Switch (LRS-11572A)
Fuel Pump
Fuel Fill Grommet (LRS-9072A)
Rear Spring Isolators (Energy Susp ENS-4-6101G)
Rear Control Arm Bolts (M12x90 & M12x110 Grade 10.8)
Motor Mounts (LRS-6038PR)
Motor Mount Hardware (LRS-6038HDW)
Trans Rebuild Parts (thegearbox.org T5 WC Master Kit)
Speedo Drive Gear (7T from FoxMustangResto)
Door Handles (LRS-22404K)
Flywheel Resurfacing (NAPA Mauldin)
Throttle Body/EGR Gaskets (BBK #1572)
Exhaust Gaskets (M9448B302)
Oil Pan Gasket (LRS-6710A)
Pilot Bearing (LRS-7600A)
Rear Main Seal (LRS-6701A)
Upper Intake Gasket (LRS-9486A)
Clutch (FR M-7560-A302N)
Performance Parts Inc Clutch cable (Ford OEM)
Water Pump (M-8501-C50)
Mass Air Conversion Kit (CH-8611-F)
Brake Proportioning Valve (M-2328-C)
3-2 Brake Line Adapter (MMBAK-3)
Rear Parking Brake Cables (2) (LRS-2635D)
Front Parking Brake Cable (M-2810-A)
Headlights (LRS-13007E-KIT)
94 GT Master Cylinder & Brake Booster (eBay)
Hood Struts (LRS-16826C)
Clutch Cable Firewall Adjuster (SVE-7553-H)
95 GT Rear Disc Brake Parts (eBay)
Rear Caliper Soft Lines (DHB-380371 & 72)
Rear End Bearing & Seal Kit (LRS-4210A)
Differential Spider Gears (Ford 2L1Z-4215-EA)
Differential Pinion Shaft (Ford E9AZ-4211-A)
Differential Clutch (FMS-M-4700-C)
Timing Chain Set (CCA-2138)
Timing Cover Gasket (FEL-TCS45449)
Harmonic Balancer (FMS-M-6316-M50)
Oil Pump (SLP-224-41118)
Brake Line Adapters (Balkamp 641-3306)
Valve Cover Gaskets (FMS-M-6584-A50)
Clutch Fork (SUM-700105)
Clutch Fork Ball Stud (MCL-16910)
Spark Plugs (ASF42C)
Axle Bearings (SKF 13992)
Transmission Mount (LRS-6068A)
Steering Rack (Cardone 22-207)
Transmission Tunnel Hump (FP20-79TC)
Fuel Injection Hose & Clamps (5/16" SAE30R9)
Tie Rod End Boots (Energy Susp 9.13101R)
Steering Rag Joint Disc (Dorman 31000)
Coolant Bypass Hose (AM 52953 / Motorcraft KM640)
PCV Filter (E6ZZ-6A631-B / FA1068)
PCV Grommet (F7CZ-6A892-AA)
Window Guides and Door Lock Actuators
Tires (Riken Raptor 245/45-ZR17)
Weatherstripping Kit (Daniel Carpenter)
EGR Spacer Gasket (FEL 70262)
Throttle Body Gasket (FEL 72543)
Oil Fill Cap (F3AZ-6766-B)
Speedo Cable (LRS-17260B)
Speedometer Gear (7T drive gear)
HVAC Control Panel
Upper Condenser Brackets (Corral.net)
Wiper Motor (40-297)
A/C Compressor & Discharge Line (Corral.net)
A/C Condenser (Spectra 7-4453)
A/C Liquid Line (Everco 3512)
A/C Accumulator (Everco 3617)
Rear Control Arms (MM-MMRLCA1) (LRS-5500CA-K)
Coilover Suspension (SVE-47375KA)
Subframe Connectors (MM-MMFL5B)
Prothane front bushings and sway bar end links (PT-19417PL & PT-6205BL)
  • Like
Reactions: Nemo6007
Save
#7 ·
Plus I have some spares like new LMR door panels, Ford racing shorty headers, stock upholstery for the rear seats to match the front, new carpet (I prefer the old). Misc parts. All comes with it. Just never installed.
Save
#11 ·
Save
#13 · (Edited)
Got it up on the lift today and took some pics. Went ahead and changed the oil while I had it up. I'll leave it on the lift a couple more days if anyone wants to see anything else in particular.
Save
#19 · (Edited)
Original color was burgundy hence the pinkish color on the underside, and yes there is a little coolant residue around the weep hole but it's not dripping coolant. Camera flash tends to exaggerate things sometimes.
Save
#23 ·
Rides great. Biggest noticeable improvement in ride was after I installed the welded subframe connectors. Made a huge difference. Paint is good. I'm going off the grid until Monday evening so I'll reply to any PM's when I get back.
Save
#24 ·
It's actually surprising how well it absorbs bumps with it being lowered where it is, but the spanner comes with it in case the new owner wants to raise it back up some.
Save
