17x9's Cobra's on the front stick out?
1.5K views 14 replies 6 participants last post by  85GTVince
#1 ·
Just got my Wheel Replica's 03 Cobra rims today. 17x9 on the front, 17x10.5 on the rear. I test fit the fronts on there to check it out and found that they stick out about 1/2" - 3/4" of an inch or so.
Anyone else's doing that? Any way to fix it?
I have a tube k, 03 cobra a-arms if that makes a difference.
#8 ·
You need Fox A-arms. The SN95 A-arms are pushing the wheels out 1.25".
--Vince
#15 ·
... but wondering if it's probly best to re-bushing and install 94+ ball joints on my stock fox stuff?
I changed it all out because the fox stuff was just plain worn out.
The short answer is, "Yes".
The slightly longer answer is while you are at it.....
1) Urethane bushings
2) SN95 Balljoint (or X2)
3) Box in the A-arm around the bushing area. (I can find a picture if you don't get what I mean.)
4) Notch the arm to clear wider wheels. (Like the '03 Cobra A-arms.)
--Vince
