157 tooth vs 164 tooth flywheel
1 reading
20K views 17 replies 10 participants last post by  raysmust
#1 ·
I am trying to figure out what the differences are specifically between the two flywheels, other than one comes on a 302 and one on a 351. Can someone list all of the differences?
Sent from my DROID BIONIC using Tapatalk 2
#11 ·
The 164 allows for using an 11" clutch. You need a 164-specific bellhousing, block plate, and a starter with the "manual transmission" snout length.
Due to original application, but not to size. Either one is available on the aftermarket with 0, 28, and 50oz balance factors.
#16 ·
Most are 28 oz, but as was stated above they are available in the 50 oz.
That 164t flywheel, a starter, and a block plate (or a modified block plate) will allow you to use a cheap 94+ 3.8 bell housing on your 94/95 5.0 if you are willing to make the car "non-standard"...
But hey, having an 11 inch clutch is an upgrade!!!
