Status
Not open for further replies.
· Registered
-i have a 03/04 cobra m112 -the bottom after-cooler square milled off like Super-six motor sports says to do..ported stock TB 03/04 cobra, custom modified intake elbow with two ports for water/meth injection - also it is cut and angled so it will go under the hood and angle toward the stock location for the air intake tube. Super six lower-intake adapter manifold--installed is a threaded piece for the air temp sensor (ats included with wiring), a machined piece that is used for pulley - belt wrap for the blower pulley(pulley included) and is also the upper alternator bolt--made of 5/8 hex, I also have a water meth kit from cooling mist trunk mount and adjustable with boost reference and tip in % of flow use, Then there is the plastic piece that goes on your steering column with the boost gauge... a plate that I made for the coil pack(04).I will include any nuts and bolts that I may still have for it also, asking $2200 shipped I made 273 rwhp and 322 rwt with this on 91 oct with a 04 six with an automatic and 8.8 rear end-stock tires-air intake tube 4 inch adapter to tb
super-six instructions
blower will not fit under the hood--I used a 03/04 mock one hood and had to notch buy the rear passenger side, and remove a little op the under structure
you will need a smaller lower pulley for your motor, a 03/04 cobra or lighting MASS--ebay $90 new..60 lb injectors if u want to use e-85, and a capable fuel pump--gaskets-belt
vmp tunning out of flordia got me a startup tune, fuel pump and lower pulley
· Registered
supercharger kit
I don't have all the parts. I do have the blower unit, and some piping. I don't have the elbow or the intercooler. This kit came off of a Thunderbird, then went on a V-6 Mustang. Make me an offer. It is taking up room.
· Registered
super coup set up
i do have all the brackets belts just add a intercooler or not change water pump to a super coup pump and make 10 psi boost i ran it 2 years till i put in a v8 you need nothing more $400 + shipping
bidman427
Status
