Just got another set of pedals in stock this week great condition.
$140 shipped
Update: This set of pedals is basically for a 79'- 85' foxbody doing a 5 speed conversion to use on car with no cruise control because it doesn't have the vacuum activated cruise control dump switch bracket to mount the vacuum switch too, nor does it have the cruise control electronic dump switch. If the car being worked on does not have cruise control this would be a good set for 79'- 93' cars.
An Sn-95 clutch/brake pedal set are a bit different but will work in a foxbody with a little bit of modifications and needing to oval out the mounting holes in the firewall a little bit.
Gearbox I have the pedal set oit of a 97 Cobra if you need it. PM sent.
Related Threads
Ford Mustang Forums
9.8M posts
200.6K members
Since 2001
