So i installed a Windstar dual fan on my 347 this weekend and with a little trimming, it looks factory! Anyway, i want to install a thermo control so the fans kick on automatically. I installed on this weekend and it keeps blowing the 30 amp in line fuse. My thoughts are that I will probably have to install 2 separate thermo controls, once for each fan since they draw so many amps. Make since? Other ideas?
Thanks!
cant you hook it up to a relay? And y not just run a switch. imo id rather have a switch. Ive had bad luck with the thermos not turning on at all. bad juju
It's not gonna be hooked up to a switch. Just a thermo deal. I'm gonna also run a small light into the interior or the car that will light when the fans kick on.
