I’m going to install the Wilwood proportioning valve in line and the Maximum Motorsports plug in the stock block. I have the MC and stock proportioning block from a 97 Cobra. Can’t seem to find anything online or on the forum to show which port does what. It does seem the port nearest to the firewall is typically the front brake line outlet, however.
If I’m looking at this correctly, the valve goes in between this port on the MC and this brake line:
The MM plug then goes here:
