Setup as follows
94 cobra stock short block 100,000 miles W/8 good cylinders
Edelbrock performer heads
Pro M 75MM cal for 36#N/A
FMS 36# injectors
The cam I have came with the K/B 2200 that I bought on the corral, here are the specs that I got from a cam doctor with 1.7 rockers as referenced
INTAKE & EXHAUST
LOBE CENTER SEP 112.1 CAM DEG.
VALVE OVERLAP .8 CRANK DEG.
INTAKE
VALVE OPENING .4 BTDC
LOBE CENTER 111.3 ATDC
VALVE CLOSURE 44.4 ABDC
DURATION 224.8 CRANK DEG.
MAX CAM LIFT .33776 IN.
NET VALVE LIFT .57419 IN.
LOBE AREA 26.51 IN DEG
EXHAUST
VALVE OPENING 45.1 BBCD
LOBE CENTER 112.9 BTDC
VALVE CLOSURE .4 ATDC
DURATION 225.5 CRANK DEG.
MAX CAM LIFT .33713 IN.
NET VALVE LIFT .57311 IN.
LOBE AREA 26.57 IN DEG
So I am wanting to run between 8# and 10# of boost with this setup and I guess I want to know if this cam is any good with the above setup or should I be looking for a different cam?
I do not claim to understand what all the numbers mean but the shop did explain them to me
Mike
Discussion Starter · #2 ·
Anyone?
oop's
Anyone?
I really could use a little advice here.
Mike :confused:
Not too sure about that cam but I do know that anderson ford makes a killer blower cam. You can check out ther website and go with either the B-31 or the B-41. Also Kennedy's dynotune has a good cam that works well with the kenne bell. Good luck.
Discussion Starter · #5 ·
Thats good to know and I may need to go that way if this cam won't work.
I was hoping someone in here would know something about came
Mike
Discussion Starter · #6 ·
