hey my damn drivers seat broke laying str8 back... will the passenger side seat mounts mount right in or are they flip floped, could i just slap the passeger seat in the driver seats spot?
thanks!
Discussion Starter · #2 ·
btw its a fox sorry figured that might be important
I switched mine in my 88...I think I ended switching the rails over and I had to relocate a hole or 2 on the rails...PITA since the recline lever ends up on the wrong side.....
Super Moderator
They will swap, direct bolt-in, no mods required. But the recline handle will be on the wrong side and that's a PITA.
Check the recline mechanism. Take the cover off. Either the spring broke or the teeth stripped.
Discussion Starter · #6 ·
"Check the recline mechanism. Take the cover off. Either the spring broke or the teeth stripped."
yeah the seats to ****ty to even look or care...
i dont care if the lever is on the rong side, because the lever is broke off...so its stuck now anyway, but its a good seat
and i dont really care its just a beater...id bolt up a lawn chair if need be
so its a direct fit no switching mounts or any of that BS
89 4cyl fox
Discussion Starter · #7 ·
thanks guys it fit and is working perfect
