I have a 1995 Cobra w/20,xxx on her clock. I plan on running S-trim, 2.95 or 3.33 pulley, stock Vortech crank pulley (6.785 or something), Power Pipe, Pro-m 80mm, 42# injectors, GSS340 in tank, and T-Rex.
I have a stock engine, equal shorties, off-road H-pipe, dumped Dynomax Super Turbos, Crane Hi-6, MSD BTM, ditched the FMU, FMS aluminum DS, Steeda adj Cluth Quad, Pro 5.0 shifter, Sub-frames, ect....
Do you think I should run the 3.33 or 2.95 pulley? Rick Anderson said I could run the 2.95 if I was running at least 38# injectors and 255 intank w/T-rex. That would supply the fuel I need. But do you think my engine would hold up very long? I plan on having AFM tune the car w/a chip burn. I am sure there are simular combos out there that could tell me what to expect as far as horsepower goes with either pulley. Thanks, MEAT315.
I'd start with the 3.33 pulley myself. Should see around 400RWHP with a powerpipe and over 10lbs of boost. I say the big pulley 1st because it better safe than sorry.;) And with a good tune, the engine should be fine.
