1 - 13 of 13 Posts
Yep, they will drop right in as long as they are the lime green tops. But you know you have to get a new MAF calibrated for them... and unless your making major power, they are overkill.
Do yourself a favor and get the Pro M Univer to match the 42's It is about the best meter for the big squirters and will make tuning easier.
Absolutely, 42lb injectors are 42lb injectors. I told Pro-M that I was using Lucas injectors, they said it didn't matter. Its calibrated for blow-through forced induction (not pull through). The tech guy recommended I draw a diagram of the turbo setup, so I did that on the order sheet which I mailed to them with the MAF.
1 - 13 of 13 Posts
