Will the fluidyne radiator fit a 94 with a powerdyne supercharger. I thought I had seen a post in the past where someone had a powerdyne and went to put a fluidyne radiator in and it hit the lower pulley or blower pulley or something. Do any of you have this combo? What mods are involved? Thanks
I had to trim down the plastic fan shroud to get mine to clear the supercharger pulley.
I took off about 3/4 inch around the entire assembly and cut off a little bit of the mounting tabs on the radiator.
Al
Yes, it will with some modification. What I did was unmount the fan from the shroud. There are three screws that hold it there. Where those three screws mount the plastic on the shroud is raised. I took that down flat and remounted. I have about 3/8" clearance now from the fan to the crank pulley.
