1 - 10 of 10 Posts
FS 98 Cobra Conv. Supercharged
Price reduced to only $19K firm. Read on to the build list...........Everything works and is 100% healthy, car needs nothing!
Dynoed at 646 RWHP @ 6300 RPM, 550 FTLB TORQUE @ 5600 RPM on safe street tune with 93 octane gas. Street driven only, very docile and streetable in normal driving conditions, thanks to F.A.S.T engine management system. Never raced or seen slicks. Professionally built, installed and tuned by No Limit Race Cars- home of the fastest supercharged 4.6 modular race car.
This car is complete, with only the very best in parts and assembly. 37K original miles on car. Only 3K miles on built engine, 1K miles on transmission. Laser red metallic exterior/black top/black interior. Excellent condition in and out. Show car quality engine bay. One drive and you’ll be sold! Why buy a ’03-’04 Cobra when you could have a fully built street (or race) car? Located in Atlanta area. Selling to buy house.
Contact for pics, dyno graph, and info:
[email protected]
(ph) 770-632-7162
-Patrick
Engine: Original 4.6 DOHC 32V aluminum block, bored .020 over and honed with torque plates. Balanced rotating assembly. CP forged dish pistons, blower-friendly 8.5:1 compression ratio, Manley forged rods, plasma moly rings, Clevite main and rod bearings, ARP main and head studs. Polished intake manifold and valve covers.
Cylinder Heads: Stage 5 ported and polished ’98 Cobra 4V aluminum heads, stock cams.
Power Adder: Polished Procharger F-1R supercharger capable of 30+ lbs of boost driven by Procharger cog belt drive system (no slip). Procharger 3 core intercooler and race by-pass valve.
Engine Management: F.A.S.T. (Speed Pro) stand alone engine management, custom tuned by No Limit Race Cars to run safely on 93 octane pump gas.
Exhaust: Ceramic coated MAC longtube headers, custom 3” dual exhaust with X-pipe, MagnaFlow mufflers.
Fuel System: Weldon 2025 fuel pump, custom sump on tank, Aeromotive A1000 regulator and fuel filters, 72 lb fuel injectors, billet fuel rails, AN-10 braided stainless hose from sump to pump, AN-8 from pump to engine, AN-6 on return line.
Transmission: PA Racing Super Comp AODE with transbrake and lock-up controls. Street friendly 2400RPM stall speed lock-up torque converter. Ford AODE shifter. Transmission cooler.
Rearend: 4.30 Ford Racing ring and pinion. Traction-Loc differential.
Ignition: MSD DIS 4 ignition box, Ford Motorsport 9MM plug wires, NGK TR6 spark plugs.
Gauges: Autometer boost and fuel pressure.
Chassis: 8 point chrome-moly 1 5/8” diameter roll bar with fully removable swing out door bars, Kenny Brown extreme matrix subframe system- frame rail, sub-frame and interlocking cross bracing.
Suspension Rear: Ford Motorsport lowering springs, Steeda aluminum lower control arms and aluminum double adjustable upper control arms.
Suspension Front: Ford Motorsport lowering springs.
Brakes: Front- Cobra twin piston PBR front calipers with 13” rotors and Hawk pads. Rear- Stock Cobra with Hawk pads.
Wheels/Tires: Front- 17” dia. 9” wide Cobra R rims with 245/45-17 Michelin Pilot Sport tires. Rear- 17” dia. 10.5” wide Cobra R rims with 315/35-17 Michelin Pilot Sport tires.
Appearance: Cobra RR hood with louvered vent detail from 2000 Cobra R hood. Sequential taillights.
Interior: Lightweight Cobra Monaco race seats (have original seats as well). 5 point racing harnesses (or stock safety belts). Rear seat delete kit.
Other: Relocated trunk mounted battery. Safety steel drive shaft loop. A/C delete.
Looking for serious offers, willing to deal. This car is built right from head to toe. No disappointments.
Had me sold for a second there. i wish it was a stick. sounds like a sweet ass ride though. goodluck selling her.
Insane deal on a built 98 Cobra
Price reduced to only $19K firm. Thought I had the car sold, but out of state buyer backed out. Incredible car! Someone will be very happy.
Car sold or still have it
? do you still have car last reply back in Aug also if you still do what is the boost your getting your 600+ rwhp
1 - 10 of 10 Posts
