The car runs in the O of NORMAL when I am going down the road, but when I stop and let it idle it gets hot... Into the M, and the fan will NOT kick on without the A/C on... I have replaced the CCRM, and the temp sending unit... What could it be?
check to see if your throwing a code first? Then if you are and you've change the sending unit etc.. unhook your battery for 30 minutes or so and reinstall then try it again. Could be a relay problem related to voltage.Check your codes first and go from there.
