it just started doing it.the car would sit for hours overnight and when i start it in the morning the high speed fan would come on and stay on.could it be a bad water temp sensor ? or something else
Randy
Could be a water temp sensor, but that might also make the engine run poorly. I believe that there is a fan relay that turns the fan on. I would be looking in that direction.
Do you have your AC, defrost, etc on? If so, that's your answer. If not, try the coolant sensor connection; the one on the passenger side of the intake. If it's loose (or bad) the fan will come on.
Tim
i will try that.thanks
I had that happen a few times. Just turn the key back and forth a few times, it will stop.
Randy
My 2001 GT does the same thing.....the sound of that high speed fan is very annoying but the dealer says it's normal. :confused:
More feedback would be appreciated.
That was happening to me all the time about a year ago -right after I installed my intercooler. It doesn't do it anymore -it behaves normally. I don't know why -its a mystery to me...
