1 - 9 of 9 Posts
I was just wondering why my Flows (with H pipe) pop and crackle when I let of the gas. I recently heard several more that do the same thing.
Is is because of the reduced backpressure in the system? Bigger chambers in the muff?
Just wondering,
Clint
Super Moderator
i suspect you have a leak in the system, becuase not all aftermarket mufflers do it, not even all of a certain brand, but if you have the air tubes still hooked up or a leak upstream it'll pop on decel. Not sure why.
Thanks MFE,
I just assumed they all did it. I do have the tubes connected and I might have a leak as well. I still have the original headers on my '90. I don't think they have ever been off and they might be leaking a little.
Good to know that the muffs aren't supposed to do that.
Thanks,
Clint
I'm not by any means an expert on this, but my guess would be...
Do you have an offroad h-pipe? My understanding on this is the Catalytic Converters stop any backfires (or popping) through the exhaust. Which would be why you didn't see/hear/experience this with factory exhaust (with cats) and are now with aftermarket exhaust (no cats).
This may not be the case, but it's my take on it.
Super Moderator
I have an off-road pipe with the air pump system disabled and disconnected and mine don't pop at all, but I remember back 18-20 years ago popping 5.0's were rampant because everybody messed with their air pumps and cats. If you keep the air pump system intact without the cats it'll pop and burble.
You've got a good point. When I had my air pump hooked up with no cats, the car popped and burbled all OVER the place. It was every time I let off the gas (even from light throttle applications). Without the air pump hooked up, this problem went away.
Also, when I had the Speedbrain in my car it would pop after I let of the throttle from a wide open throttle. I'm sure this had something to do with the amount of timing or fuel I had in it.
The Air pump is probably the problem in this case though.
I have no air pump and no cats on my car and it pops and crackles ALL the time. It didn't do this as bad before I had this new camshaft put in.
While the car was down for the cam I had my tranny rebuilt so the X came off. Maybe it wasn't reconnected properly.
1 - 9 of 9 Posts
