I am looking for prices on 6.2" rods, in order to create a 377 stroker with a offset ground 351w crank. I would only need the less expensive version of these rods as this is a street vehicle. If anyone knows of someone I should contact then lemme know, otherwise I will contact summit and jegs.
Also if anyone has any input, as far as, building a 377 by offset grinding the 351w crank and using 6.2" rods, then let me know the pros and cons. Keep in mind street motor. Thanks
357f-150
