When I use the radio I hear nothing but music. When I pop in a CD or DVD I hear a lot of the whining with the RPM increase. Usually everyone is quick to point to the grounds to make sure they are hooked up right. But now why would it only be the CD player and not the radio? This would cancel out the amps and only point to the head unit if you ask me? When it the problem?
you may want to try a ground loop isolater it is designed to help cancel out noises caused by the engine, wipers, fans, motors, etc... you can find it at any local electronics store i would try radioshack. or a your local car audio store.
