I'm looking to buy a saleen-type wing for my 88 hatchback. I've seen two different brands, both essentially the same model, only one costs $149 and one costs $239. Does anyone know the difference?
There is the saleen clone wing and then there is the Dugan Racing "Whale Tail" but I'm not sure if they make it anymore...it was a little more rounded and slightly better looking than the saleen. personally I want to be alil different and am going with the steed LX style wing
what companies are the 2 wings from?
check to see if the cheaper one comes with hardware.
also the quality might be the reason, cheaper might require more bodywork etc.
Discussion Starter · #4 ·
what hardware would i need to install a wing? i can probably use the brakelight in the wing i have now, but is there anything else?
just rememebr yuo get what you pay for. GO for the best quality yu can afford it will save time and headaches and having to do a lot of work to the part to get it to look right. I have done a lot of work with fiberglass and nothing is worse than buying a part to have to do a ton of work to make it look right.
