As you know, the 98 cobra (or 98 In general from what I understand) uses a different pump than the 86-97. I know the 86-97 pumps can be modified to work, but I'm interested in plug and play...I DONT WANT TO WORRY ABOUT MY PUMP UNDER BOOST.
Where can I find a pump, 255 High pressure, for my 98 cobra....or does anyone have the walbro part number?
Thanks!
the walbro will work, you just need to enlarge the hole in the top of the canister to accomidate the larger pump. Once you get it out and put the new one it is very obvious. Just Do not make the hole to big or your SOL.
