I am looking at getting the wet shot on my stock short block or the dry kit. Not really sure which one I should go with right now. But right now I have 19lb injectors, Ported Twisted Wedge Heads, Ported Cobra Intake and E Cam and 65mm TB.
it all depends on the shot right now with your setup you are way pass the limit of those 19's on motor you might want to throw on some 30lb and a prom 80 and spray a 175 with no problem and of course have the car tuned
Yeah I know the 19lb are too damn small right now that is why I was debating on which next size I should go with and more then likely it will end being the 30's
well i would suggest 30 because just in case you decide to get rid of the cobra intake and the e cam and TB to better and bigger you have enough fuel iam changing my setup as we speak to all trick flow stuff except for the cam which is custom for nitrous and a 200 shot plate is going in and i am going to use 30lb
Now is it true if I go with a wet kit from NX that I will not have to get that big of Fuel Injectors
