When looking at the tank from above (after dropping it).
I am having trouble with leakage from the line most toward the front of the car (with the rubber grommet that fits into the round hole). I have a post in Nitrous asking a similar question.
Thanks.
The larger line is the feed line. If you are having trouble figuring out which that is ( they are close), follow the line to the filter.
Good Luck
Yea, I'm sure I could find which one is which coming out of the pump, but this is the one that is separate from the pump assembly---is this just the vapor line???????????
