Where should i hook up the vacuum line for the boost gauge on my 5.0 with s-trim? I have a bosch bypass valve if that matters.
Thank for the help
You can hook up to the vacumm tree under your hood. You may have to get a few fittings to make it work but thats what I did and it works good.
the vacuum tree on the drivers side where the power brakes and such hook to??
Thats the one... You may have to use a vacumm "T" adapter and an adapter from the nylon boost line to fit the "T".
Just experiment, its not very difficult
to your upper intake anywhere after the throttle body.
there should be plenty of fittings/sources already there to hook it up.
use the source that hooks up to your adjustable fuel pressure regulator
