Getting ready to change mine out. Is it tranny side or behind the speedometer...???
it's on the driver sd of the tranny....1 bolt to remove and the gear is held in by a small clip....it's been a while since i've done mine so i can't remember exactly, just look for something being held in by one bolt on the driver sd.
Thanks guys, right after I posted I found it. New speedo gear works like a charm...! It's nice to know how fast I'm going again...!
wait, i thought that to change the speedo you needed a speedcal. I was wondering because i have a 97 and was planning on getting gears, would i be able to use a speedo gear or do i need a speed cal?
For 96-98 cars you have the option of a driven gear as well as an electronic compensator. Depending on how steep your gears (4.10's or higher) and what kind of error in the speedo/odo (1%, 5%, 10%, etc...) and cost (gear is $15, SpeedCal is $90-$100, Abbott is about the same) determine your course of action. Electronic compensators like the SpeedCal will get you within 1/2% or better. A driven gear can get you pretty close in too depending on the ring/pinion choice
