Every 2-3 days I have to refill.
I cant tell where it is leaking. I can park it on concrete and nothing will show up. Not even a drip. Yet I still lose it.
Ive also checked the oil, no water there either.
Anybody have any tips or know how to find a coolant leak?
If you get one of those stethascopes for cars you can run it along the heads and listen for air. You may even look for oil or a wet spot on the engine. If you get a telescoping light and mirror you can look on the "inside" of the engine under the intake in the canal.
Also make sure your fill cap on the overflow reservoir is on tightly as well as the fill plug on the water tube.
I do have an oil leak, but I have had that for several months (infact almost a year) before my losing of coolant.
Are head gaskets hard to replace? Can a backyard mechanic do the job?
I have a lil bit of know how.
On our motors, yes.
No need to do it though unless you know proof positive that you have a blown head gasket. Exhaust all other possibilities before you look there.
